agree
facebook is not twitter
if i wanted to read twits, i would join twitter and read them
in other news
didnt bother replacing projector (our dell one died)
not worth the $ and stuffing around
got a 50" installed on the wall for 600 so pretty reasonable
a projector would have cost me about 1200 ish
is only a small 3x3m room so 50" is actually pretty good size for the area
agree
sometimes I cbf posting the same thing on both, so I tweet and FB status update on the same thing (using Tweetdeck). You may end up with a hashtag or two. Don't like it, tune it the fuck out by unsubscribing. It's not like I have a gun to your head telling you to read that shit.
Failing that you can ignore updates from the Twitter or Tweetdeck app. That way any FB update from twitter or a twitter-centric tool won't show up in your feed.
People who post hashtags on FB without any link to twitter tho...
I need an accountant or a hook up to one that can help me maximise cash monies. My previous one just skipped the country to NZ.
PM Tony aka blah_blah on here, he's the bean counter.
Or the fact I'm only running 19psi and a 3" exhaust at the moment? :)
to those kind of people mods don't mean anything
dyno results rule all :P
Lambos are for kids
Get a brabus
brabus nice
True Alex.. can't dose the latte sippers lol :(
I've got a thing for Italians Rimon
haha obviously :P
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
