No idea, I went on there to post in some thread ,... couldnt do it checked some shit apparently I've been banned from posting ... hahahaha I usually get in there and make threads about drifting lavo factorys n stuff for lulz then they shut down the threads.
I have a dilemma, that is what way to go to London via.
There's some of the routes enroute.
Beijing
Beijing & shanghai
Dubai
Abu Dhabi
Bangkok & Cairo
Kuala lumpar & Bangkok
Hong kong
And few places in middle east region including Jordan, Qatar.
If go thru china, the flight will be the longest but it's whole heap cheaper.
Hong Kong is pretty expensive - only available if using Qantas, Cathay Pacfic.
I'm leaning towards middle east route unless I want to see if there's counterfeit goods on duty free in china.
So far dad and both my brothers tried to talk me into staying Dubai for couple of nights...
/tl:dr post.
ive been hong kong / beijing / bangkok
out of those 3 id say go hong kong by far.. beijing is 13 hours if i remember right, bangkok airport is like a military controlled complex, they have their military people with machine guns on them at the airport...
but on the other hand - dubai and abu dhabi could be funs! :D
Thing is, I'm not looking to spend $ on stop overs cos I'd rather waste it in UK/Europe as I'll probably spend up to 2 years there - have work visa in the UK.
Been to Bangkok airport something like 7-8 times over the past 6 years
Honestly cannot remember any Military presence on any occasion.
Beijing
Beijing & shanghai
Dubai
Abu Dhabi
Bangkok & Cairo
Hong kong
/tl:dr post.
Counterfeit stuff cheaper in HK or bangkok
add in if you want to leave airport in China there is a visa so there more money to spend.
accom in Dubai and Abu Dhabi can be very expensive for safe good accom, (and you will have all your stuff with you)
that said like all things with airlines you get what you pay for.
and remember you will be stuck in your seat for upwards of 24 hours.
so things like:
every seat in economy on Cathay has it's own power socket
Qantas 380 has a (non alcoholic) bar where you can get drinks and snacks any time on the flight
so is the important thing
cost
stopover
comfort on flight
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
