It's pretty much a brand new bike so there shouldn't be any real issues with RWC....Probably gonna have to swap the pipe back to the stocker, although it'd be good if they let it slide when they know I'm just gonna put it straight back on as soon as I get home anyway..
Does the black screen affect RWC at all? It's not like you look through it...
He's cut the fender so it's hidden behind the license plate, but I've got the bottom half so I'll just have to find a way to secure that to pass the roady....
Apart from that it's stock so should be sweet...
After all that's sorted, gotta get a real fender eliminator, and another seat cowl...The one he gave me doesn't secure properly so it'd flap around a bit at any kind of speed..
Basically the way rwc's work now is they need to be photographed, so it's got to look road worthy. It's possible that some stores could be harsher about it but in regards to the pipe, my friend who owns a store and does rwc's said if it has a baffle they can generally say it meets the sound restriction so they don't need to change it over. Tinted screen is technically not road worthy so that may need to be changed. Not sure on the fender, if it can look like it's attached in a photo then it should be fine but it will depend on the store. If you end up needing to buy a new windscreen I would recommend Screens For Bikes. Probably will cost less than an oem at least :)
Nah I've got the stock screen so I guess I'll just change it to be sure...
Same with the pipe, looks like it's a pretty simple swap
Hardest part will be the fender as he's cut it with a grinder or something and melted the plastic...Will need to work out a way to fix the bottom half of it so that it looks half decent...
Really? All the bikes I've bought and sold have passed first time, whether they need to be slightly modified on the spot or not. Being road worthy isn't a huge feat on motorbikes and since this is a young bike I would recommend being prepared so you don't risk paying labour for them to do the job for you or prolonging the time the bike needs to be in the shop.
got a ODB cable for my ba falcon
some of the guys on the forums have worked out how to play around with the clusters
police mode enabled on my ba cluster (not really that exciting) and no signs of any errors or cluster swaps
which is a bonus, looks like the 100km on my cluster is legit
Think that's the one I was looking at getting
Mother f**ker!
Pics? Price?
Didn't open the box till I got home, knobshiner gave me the wrong helmet ffs have to go tomorrow and exchange it
was meant to get this one http://origin.kaboodle.com/hi/img/b/0/0/1af/b/AAAAC2jqnIMAAAAAAa-1AA.jpg?v=1322285087000 My link
Yep that's the one... How much?
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
