1333939875[/url]' post='6308324']
Tarneit/hoppers crossing/Werribee
I really recommend Platinum Motorcycles in Keilor East. It's just off the Western Ring Road so it's quite easy to get to.The guy who runs it, Louie, knows his stuff and is honest too. He's been working on bikes his whole life.http://www.platinummotorcycles.com.au/If you do go, tell him O'C says hello
not a great deal in the end
on the old falcons they had a dedicated cop cluster
that was used so it had digital speed readout and peak speed save / recall setting etc
nothing "important" and it's not a "cop chip" tune either
but they had to swap it out when they sold it as a normal car
ie a pain in the ass, but back in the old days
these days its just a toggle setting
you can turn police mode on and off on any ba cluster via the ODB port
in fact, you can change the whole car, including remapping via ODB port
on the BA
when you enable police mode
the cluster simply shows digital speed in km/h (and speedo dial) and has a top score / speed recall feature
normal BA cluster has like fuel economy on avg fuel etc
this is all disabled in the police mode to show you digital speed read out (and speedo dial)
theres also some other trick to make all the lights go off in the car
like the interior ones again, nothing special
R33 GTR's already look good on it own, maybe the Nismo 400R kit, but I quite like the Veilside kit. Looks Tuff!
tumblr_lnvvueuSsj1qcj56b.png?1318394475
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
