salmonella.
the possibility isn't very high though.
apparently free range chicken that has no steroids for growth can actually be eaten raw as it doesn't contain salmonella
but thats just something I heard, I wouldn't do it
Men?
lol
emo mo mo mo mo mo mo mo mo mo mo mo mo mo mo mo mo mo mo
my housemate, is seriously annoying..
jay-sarn?
new battery in
spark plugs changed
mthrfkr still wont turn over
time to drop it off at some kunts shop
If you can be bothered making the distance, drop it off at MotoHeaven in Brighton, Adrian is a good guy. Saved me hundreds on servicing my bike.
nah f**k that,
I've had dudes OD and kick it in shared houses.
Chicks loaning their rooms to friends to f**k randoms
screamers...nuff said.
and final straw pron fetish dude who could watch 4 porn movies at a time, then was going thought our rooms duding day in case we had some a he needed more...
the day I could afford sole accom was awesome.
shiiiieeet. but makes for funny stories.
ive lived with drug dealers (and done urine tests for them), a dude with short term memory loss, new zealanders, red heads, dole bludgers, pommies and a guy who slept in the garage sharing a double bed with his dog.
good times
Lol. nothing as bad as you guys have experienced, and nothing as bad as the previous house where i'd see entire bags of chicken/fish disappear from the freezer, generally dirty behaviour.
But as this guy is a mate's cousin, i thought he'd be pretty nice. He is fairly nice, but he's just so full of shit, asks for advice only to argue against said advice. Tries to give me advice about doing assignments even though, i'm in engineering and he's in commerce, and he fails 2 out of 4 modules per semester.
That kind of shit.
I can afford individual housing, but then i'd not have this awesome garage and driveway and kitchen, so give and take i guess? Them pinching my rice and denting my knives i can deal with, as long as my wagyu doesn't disappear without my knowledge.
it was only the 3rd of May, so no big deal.
currently living with a female same age... women are much better than living with dudes (if they arent psychos), as long as you dont over step any boundaries... was given the advice "dont screw with the crew" and have stuck to it.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
