move house
call foxtel and arrange appointment - takes 1 week
fox guy turns up.... informs me cant have cable as the dick next door cut the cable and fox arent' allowed to reinstall it.
fox guy then puts this in system as "line of sight issue" meaning satelite is declined
call foxtel and explain situation... no avail
call foxtel and demand satelite... satelite approved, call back in 4 days
call back in 4 days time... satelite pending approval, call back in 2 days
call back in 2 days time... satelte denied due to line of sight.
crack shits and demand satelite team to come to house - takes 1 week
satelite guy turns up at a different time to when he was booked, calls me and explains that of course my house is fine for a satelite. advises me he will rectify situation and to call in 2 days
call back in 2 days time... satelite approved - however still need to update address as satelite not cable. - call back in 2 days
call back in 2 days... still not done... call back in 2 days
call back in 2 days... done - satelite install crew booked. - this will take 2 weeks
2 weeks later, install guy rocks up... at 7 am... its a cable install guy, NOT a satelite install guy.
call foxtel and ask WTF? foxtel advise me that my address is a cable address - not a satelite address.
crack shits and tell them to change address to satelite. - advised this will take 2 days
demand to speak to manager - same story.
call satelite company, NOT foxtel... whole thing sorted out in under 3 minutes. - satelite guy rebooked.
now waiting for him to show..
currently he is 2 hours late.........................................................
Boot is different on USA version ad front bumper
Deffs need to get blacked tail light billy!
They are meant to be the same exterior, just rebadged. Only reason it'll look different is because it ain't a proper picture of the car
move house
should kill him when he gets there if he is the wrong person again.
thats f**ked up.
not good hamish, id put in an internal complaint for you via telstra but i cant because foxtel is seperate everything :(
hope it all goes ok
let me know if you get dicked around ill see if i can flag it internally somehow if they dont help
lol Hamish...jimmies status: rustled.
It's unbelievable what happens these days when you deal with the deadly combination of strict bureaucratic processes and pepole who don't do their jobs properly.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
