They are meant to be the same exterior, just rebadged. Only reason it'll look different is because it ain't a proper picture of the car
Toyota version still looks the best out of the 3.
The front looks most aggressive.
Subaru looks most tame.
Scion is just the Toyota version but suited to how the USA want it.
Scion tail lights on Toyota version would look good.
notice how my jimmies are no longer rustled?
thas riiight... fox is installed
Shhh no more tears, only dreams now.
American Dad on Comedy+2 (ch.153) @ 2pm. You can thank me later.
they're these, similar to cv5s but bit different.
http://www.ebay.com.au/itm/19-FORD-MUSTANG-GT-GT500-AVANT-GARDE-M550-CONCAVE-GRAY-STAGGERED-WHEELS-RIMS-/360457644964?pt=Motors_Car_Truck_Parts_Accessories&hash=item53ecf32ba4#ht_7043wt_1065
They'd fit mine but won't be too aggressive, after putting my 19s on again today as well slightly annoying scraping exhaust on my driveway 20s gave it a little boost up in height.. but less traction / tyre choices..
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
