Reading up on the engine that will be going into the 86/BRZ. Subaru are putting a twin scroll turbo version of the engine into their 2012 Legacy GT. Potentially easy transplant into the 86/BRZ? 221kw and 400nm...
Yeh the ft86 run a compression of 12.5-1. Good luck to people who want to turbocharge the thing without either e85 or a decomp plate. They should have put the Subie version in all of them
It wouldn't surprise me if the second release of the 86/BRZ came with that turbo engine as an option anyway - it would be the logical choice if they were to release an "R" model - just a question of whether it fits into their marketing plan or not.
I think it all depends on the market that buys it I think. From a survey that merc are basing their upcoming range on is kids don't want fast car they are trying to get into classy things.. So mercs new range is aimed at kids, especially the price range..
Toyota wont put turbo charges motors in unless they're diesel because I reckon to have that option it's going to be f**king expensive with too many competitors
Well the Merc survey kind of contradicts the existence of the 86, which is as far removed from a Benz as you can get...but also a new car aimed at young people. The closest competitor I can think of in the expected price range of the 86 is the Golf GTI or MX5 and even then, they are completely different cars. So assuming the 86 succeeds at it's own target market, there may be room for a turbo model afterall.
That being said, I'd expect a turbo version to add at least 8-10 grand to the pricetag of the 86, with upgraded brakes and wheels etc., which would push it into Golf R32 / STi / Evo territory?
Well they obviously aren't aimed at the same market then. A turbo model would suit a mid 20's age group. If they are putting it up against a hairdressers car then they will definitely not turbo it. I guess they'll have to wait and see what market is buying them.
Nunawadding toyota have already asked a certain person to create the official optioned turbo kit for them, and kind of laughed when we found out the compression of em
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
