try $250 and then another $250 for a wine match
I'll be eating there for the 3rd time in a few weeks... cant wait (first time at the new venue)
in hindsight proposing to the mrs at the chef's table there was proably not the best idea, as she wants it to be an annual trip now lol
Hahaha money
Lol cot dayum, lucky my Mrs isn't really into fancy food.
What's your opinion on the best all you can eat?
IMO mines the all you can eat at the Langham Hotel, alot better than other places such as the Conservatory @ Crown, RACV Club CBD or New Quay Docklands
Langham was good before they jacked the prices! Valentines day was about $150/head. It used to be my favourite buffet in town, but it wasn't that good lol.
What did you expect from a N/A Subaru Impreza...
I dont doubt that. And I have a pretty good idea of the person who will build one of the first kits, in vic anyway. But I'm saying it's definitely not going to be as simple as bolt on mods and a tune, unless you want to run 1psi
Ethanol + 6psi.
lol... hit up huxtaburger man
Tis on the list.
best steak i have had was the 180gm score 10+ david blackmores full blood wagyu from bistro vue. was even better than steak i've had at the actual vue du monde.
180gram....Do they make a version for men as well?
Come at me 'fine diners'
Everytime I've gone it was about $70-$80 a head. Though havne't been since last year. $150 might be for the extra rose and candle they have on the table for you :P
Tis on the list.
considering the price of the cattle... no ;)
also being a rump cap they aren't that big
Hamish I think you need to apply for 2013 Masterchef
not eligible dood - ex professional chef with ato records that are easily referenced
If I'm spending big bucks on a steak, I wanna be full. f**k the fancy shit
small courses are part of a meal, it's not like you go to a restaurant and get a 50gm steak and nothing else.
vue du monde is one of the most filling restaurants i've been to and each course is 50odd grams. last time i went we had around 23 items each, some bigger some smaller with a wine match.
full was an understatement
I'm with you, not that I'd eat half the fancy shit anyway (inb4 Hamish), but I don't want to be craving a quarter pounder meal on the way home from dinner.
Shame you're westy, stone grill at Paesano Knox is $30 for a 250g eye fillet and $15 extra gets you another 250g piece of meat = very satisfying and cost effective way to eat good steak out.
for steak i love stefans on whitehorse road, one of my fav places for steak etc
its like $60 per cut of meat with sides included
ive been told vlados do a great steak too but pretty sure prices are even higher..
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
