Vegiebar on Brunswick st?
pfft, that joint was flavour of the month back in the 90's
might have been hipster acceptable for the duration of 3:32pm-4:14pm on Friday 17th March 2012, but even that was strictly for kitsch value.
fact is that you can never know where the hipsters will pop up as it is guaranteed to be somewere "you would have heard of" In fact the only thing that is certain is that they will serve melbourne bitter.
so get this for fucking stupidity...
I just got a call from keysborough golf club telling me that my old man cramped over in pain and then fell unconscious with his eyes open.
ambulance was called, he has now woken up and is refusing to go to hospital. he has instead decided to finish his round of golf. - despite the face he may have just had a heart attack.
i'm in the city, so there is no way i can get there in time, so my mother is en route as we speak.
I have called the golf club to get them to call the nurse on call and make him speak to them, who knows if he will though
also he has turned his phone off
Something my dad would do.
Hopes he's ok bro! Just leave nab they won't mind dude
he's at home now, mum is on her way over. there's no point leaving work man, i just spoke to him and he's refusing to go to the docs. mum might be able to convince him but i doubt it.
i'm self managed, so i can leave whenever, it's just that there is no point as it will take me a solid 90mins to get there and mum will be there sooner
Yeh this is true. Your mum should be able to talking him into it.. Women are good at that shot
Hate to say it being your dad and all Ham, but Darwin was onto something. When there are people dying of terminal illnesses and doing everything they can to stay alive, people refusing simple precautions for things like this are a bit of a pet peeve.
Age and stubbornness are heavily correlated.
dont't worry man... i totally agree :/
On topic, noticing more and more my dad taking after his old man (not with us anymore) in terms of senility and stubbornness...to the point where, like my grandfather, I can't reason with him on a lot of things. It's scary to think that I'm headed for that too...I'm already pretty senile and stubborn :/
The look of dismissal on his face after I suggested he get his Cobra polished and waxed because the paint would look infinitely better ("It already looks good!")...oh and he put one of those $15 eBay resistor things into his old Cobra, then tried to tell me how his economy and power had improved significantly -_-
you'd dad's not senile dude, he's just stupid
:P
Sounds like hipster talk to me
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
