then why didnt your say it looks like a GTB4 instead of saying it looks like a GTR with 2 extra doors..
technically its neither of them so by saying it looks like a GTR isnt like saying im building a GTB4.
oh f**k some good fishing going on in here.
because no one knows what a GTB4 is
because you keep taking pissy little cheap shots, and im just going to feed the childish troll.
my jimmies have not been rustled.
i have a feeling your jimmies have indeed been russled, especially when you had a little tantrum earlier..
lol f**k up chocolate.
when are we all catching up? seems to be no events for a while :/
At the end of the day for an Individual Tax Return, all an accountant is doing is inputting what your already entitled to.
The fee paid should not be correlated to the tax refund received.
Unless the Accountant has devised some tax planning measure that was used to generate that refund.
i.e. the Same work required for Joe and Jane. Joe needs to pay $500 in tax and Jane gets a refund of $500. They both should be charged the same amount for the work that has been done.
Note I'm only referring to simple Individual Tax Returns
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
