Alv - now that you're an eastern suburbs kid, have you tried Rich Mahas yet? I know it looks like shit, but this beef curry is decent and there's no better roti in Melbourne.
Prolly should have instagrammed that or something, clear images don't do it any favours lol.
i tried rich maha 3 years ago.
Lol. mango lassi is pretty good to go with the roti. so, when do you wanna go? i hate how oily their floors are though.
track only?
i'm not going to be doing many track days, so street pads around 90/axle is enough for me.
track only
ya using app's front and racebrakes rears atm, paying much more than that but that said been stupid happy so far.
Ate too much...feel sick. Nothing to do with what it looks like, I swear!
Yer not the cleanest place, but they've gotten heaps better - I think the health department must have paid them a visit. Gimme a couple weeks...this is one of those cuisines you crave and then don't want for a while lol. In the meantime you can pick a place instead.
Lol. well its exam period, so not really keen on leaving the house unless i need to. + the fact that i'm coughing every 5mins means i'm not fit to leave the house either.
and then i'll be in brissie for 21st june onwards, for 2 weeks. So you have your couple of weeks. =D
I am currently craving for some roast duck though i'm not supposed to be having any. just a random craving.
track only
this is why, i cant afford track (yet)
not a good driver in any way too. i'll stick to hooning, i mean, being a car enthusiast on the street.
uncle of mine owns the joint. haven't eaten there in years. food tastes good, but so much oil!
haha its not my arteries that have to deal with it the next morning. like a greased monkey on a bobsled track
Hahahaha! Probably comes out looking better than it does going in LOL
Lol I'm guessing that's the Rich Maha outside the Vermont South shops
HA
both richo and I ran A1RM's for 12 months
great entry track/street pads.
then when you get fast find ones that suit your driving
not that I'm saying I'm fast yet but hey having fun.
Forgot you were a V-town local...you been?
I've been once or twice and wasn't the biggest fan, but that might be due to me going on non-peak times so not as fresh as it could be.
There used to be a Rich Maha in the city off Collins street which I used to go to quite regulary during lunch, I always thought the food there was quite good.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
