well wildfire is basically napalm,
and napalm is basically petrol + styrofoam and other thickeners, dissolving enough styrofoam into petrol will make it annoyingly sticky and viscous enough to hold on to anything and burn.
if you want it a little more vicious, KNO3 ground fine and suspended into that liquid will provide more oxygen enabling the mix to burn hotter. If you're even more sadistic, sulphur will reduce the ignition temperature, and powdered charcoal will raise the burning point even higher.
the final result is hardly a pretty green but if you're taking part in a riot and need to spread some riot police. there you have it.
substitute KNO3 for ammonium nitrate in the mix and you've got an ANFO bomb. need to calculate stoichiometry if you want exact figures though.
Your such a terrorist lol
Cot dayum
So you can make this
Your BSB and A/c Number so I can make the deposits?
green is from copper, and that effect is from about 100kg of green sparklers.
no more lab open to me. i can tell you how to do it, you can do it yourself.
Back in my day, if you wanted to get back at someone chemically, you'd steal one of their floppy disks, open it up, cover the film in nail polish remover and let them set their computer on fire none the wiser.
you're only 2months older than me.
but how come, when i was getting back at someone chemically, i mixed bleach + hydrochloric acid and chucked into his house.
the technology is too far apart, damn you whites.
You gave him some water and chlorine gas? I don't believe you...
