btw does your bike have a display that tells you what gear you're in?
Yammies don't have them, Gixxers do, Honda's generally don't. You can buy them separately though.
Yay MotoGP is starting :)
Waited all day for your call Az...devo man :(
yeh i ended up going on the ferry dude.. plus coming back too many popo..
Touche. Thought they'd do it inside. And as soon as I had that thought, realised why they wouldn't do it inside. Lawls with this weather, fun times ahead then :/
last time i did a legit one he said the rain makes the sound level louder? lol i laughed a little inside when he said that
haha, "definitely just the rain mate, plz pass my 200dB exhaust :D".
picked up a stock exhaust to swap it over with, hopefully it all fits (was gonna chuck on a nismo one (ft. valve), but the brackets didn't line up and so couldn't straight bolt on :( ) this time.
anyone know if i were to go to an exhaust shop, how much would they charge for this like 10min swap over job LOL; i would usually do it at my mate's place (he's got a pit... next best thing when no hoist :P) but he's a bit busy, and deadline for EPA is approaching (and even earlier cuz I'm going overseas in just over a week :D). or maybe just find some wheel ramps... :P
anyone know if i were to go to an exhaust shop, how much would they charge for this like 10min swap over job LOL; i would usually do it at my mate's place (he's got a pit... next best thing when no hoist :P) but h's a bit busy, and deadline for EPA is approaching (and even earlier cuz I'm going overseas in just over a week :D). or maybe just find some wheel ramps... :P
My EPA's cost me $100 ;) lol
ARTZ popo was in frankston area. Kaz got done
seriously the guy must have been freaking out, it was after the end of the official cruise so I don;t think anyone was doing under 110,
so he picked the red car...as every-one knows red cars are fastest!
Haha he pointed at me as I went past.. But the long trail of cars behind me wouldn't have let him through
Lol nah no test. No need to change exhaust no hassle just cleared :P
that's what i was getting at, re: earmuffs :P
dogdy dodgy :)
don't mind changing mine over to stock for awhile, my ears will probably thank me. and time to get some new speakers and a sub in imo. soon.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
