yeah, my prof that i was doing my final year research project for transferred to Uni of Western Syd.
Project supervisor offered me to work as a research assistance engineer for him and i turned him down thinking I don't want to hang around Uni... how stupid was i.
So close to graduating yet so far, frustrating.
Get a job and claim the first 3 months of work as work experience.
Only thing I have to say is for all those studying and doing double degrees etc.. is that it's all good as long as you do something with it.
I know plenty of brahs that do double degrees in what not, but end up getting/wanting a job that didn't need it or still end up working at Coles etc..
Also what subject you study does depend what University is best but. University of Melbourne is ranked as the #1 University in Australia and 37th in the world :P
Edit: Depends which source you read but Melb Uni might be behind Australian National University.
inb4 methodologies are crap
What up my fellow Melbourne Uni brah
The Times top 200 list is considered the most authoritative. Melbourne has been Australia's best in that list for the past few years, ANU and UNSW not far behind.
UniversitiesAustralia
Pat since you require separate invites to events, you going to Garage Cafe tonight? :P
You must have gotten a pretty high enter score to get into Law at Melb Uni? 95 +?
Uni can be tough. We joke about it being a bludge, but when you are actually doing the work, shit can really rack your brain (regardless of how well you study). And you see no immediate reward from it like your mates who went straight into full time jobs. Even apprentices on minimum wage earn from their learning.
There are awesome things about uni - I'd choose the lifestyle over fulltime work any day. But I do remember staying up 36 hours straight to finish a lab report once (got an HD for it!), and that was harder than anything I've done in fulltime work.
Everyone's got problems at their own levels and problems are shit regardless of where they sit on a scale. You can say "that's nothing" when looking at someone else's, but then there's always someone who has it worse than you too. I guess moral of the story is no one should complain or everyone should complain, just don't complain about complaining lol.
/4cents
Oh and Nick...anyone who works in a family business knows it ain't 9-5/7, that's just what the payslip says lol. Even outside the unpaid overtime, the future of the business and day to day running sits at the back of your mind, day and night!
Higher...
Minimum enter for hecs place was 99.45 in my year
Farrkkk...
Are you one of those who did English, Maths Methods, Specialist Maths, Physics & Chemistry?
Ric now officially the smartest guy on Wastelands
That's like the standard year 12 for engineers
mine was English, Maths Methods, Specialist Maths, Chemistry, Accounting, Comp Sci
fun
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
