would be better if they sent em back to Germany so I can do laps of the ring.
Oh well hopefully it books soon so I can enjoy some warm weather again!
Germany's quite nice at this time of the year, I want to go back just for the beers.
Thinking of Nurburgring or road trip across Switzerland, Italy, Austria, possibly Czech Republic. Need to crunch some numbers before deciding.
also copped my first speeding fine since i got my license like 10 years ago..
came home to it sitting in my letter box
57 in a 50 zone - they dropped it to 54..
damn $$$$
if you havent had a fine in that long you can write a letter requesting a warning and you'll get out of it
basically have to say yes i was speeding im sorry it was an accident but given my clean driving record i believe it was a one of incident blah blah and no fine for you!
Yup, had a momentary lapse of concentration, have not slipped up in years and feel embarrassed that you were even a few km over blah blah.
It's just porn mum, and it won't go away...
Wouldn't the racist thing be "dark skin not welcome around these here parts"?
Seems to me they're welcoming you and your super tanned buddies.
P.S. New skin is frikken awesome.
While we're on the topic of resprays, was thinking about getting a cheap respray for the R33 instead of f**king around with paintless dent removal for the hail damage...what colours do we recommend? Wouldn't mind staying with silver or a variation of it, then I could do exterior only or exterior and door jams.
you would still need to fk around with pulling the dents anyways. Unless you bog it all up haha
Go for a silver but look around for a pearl or flake colour which catches your eye.
Or go for a darker shade of silver but not dark enough to make the engine bay and door jams obvious.
kappish?
edit: charcoal
what so we werent welcome round these here plaaayces before?
no idea whats happened but apexi are selling ECR33 and ER34 powerfcs new again
ahh yes i saw this a little while ago, probably make a fair bit of coin from it too considering how sort after they once were!
haha, if you want spicy ive heard crazy wings in glen waverly are the devil!
I've heard about this place, going to have to give it a shot!
Anyone going to the VIC Imports meet this Sunday? Thinking about heading down
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
