Well if u can pick up another caliper tonight it would take about half an hour plus a brake fluid bleed!
Problem is, I don't have either and have never done the brakes before.
oh gosh, wish you were my neighbour Aaron!!!
I remember some 25GT taking like 1 minute in the opposite lane trying to over take someone, that was funny.
There wasn't anything really bad that happened.
Just a lot of overtaking. Dont remember any burnouts or anything.
Edit, I remember justin being fed up with someone going slow in front of him, so he went into another lane and boosted off, only to see a speed camera right in front of him, *slams on brakes*
Srs, that looks like some normal orange, yours is some metalic with some yellowish pearl in it. Looks way better. Your wheels too :P
agree but I would love some of those rear fenders so I can straight my rear wheels
Ide help out but I'm in SE subs. Just undo the rear bolts holding on the front face of the caliper and try and in seize it. You should be able to. Then just do em back up. Might get you to where u need to be, and if it does un seize then atleast if it f**ks up on the way u can do a quick temp fix.
But I seriously wouldnt be driving it. If the brake is clamping your going to have some serious heat issues and break something
my 2530 sees the light again! A bit dusty, nothin suss with the actuator. Its stock :ph34r:
Anyone have a foot pump with a pressure dial gauge? Want to check if ive set the actuator correctly... From what I could make from the japanese instruction manual, it says 179mm for 1.0bar. Although heaps of thread still remains. Does that mean I can go for moar? Can someone plz translate the table? Thanks
Cheers for the advices Aaron! Will give it a shot if not I'll just quickly pop into Brake Plus or something tomorrow and hope they do it fast.
*tsk tsk* Good ol' Justin haha
It says if you run too much boost, there will be danger to the manifold
I'm doing some work with my cousins business to help him out with the social networking side of things / help getting his name out - basically it's a small online JDM car parts store and quickly building in size. Like on facebook if you feel like helping out :)
http://www.facebook.com/jdmracingau
a link to the store is on the facebook page.. check it out
also he's started up a youtube channel for product reviews and events / trackdays etc. and we'll be doing some "driver profile" type videos in the near future - so will need a few different cars / people I'm sure I'll contact some of you about this in the future!
/shameless plug - sleep time now brahz
THAT WAS ME! >.< Bloody bitch next to me was speeding up as I was trying to over take her... Twas rather frustrating... Especially being N/A :-(
As for an incident, there was one overtaking incident on the GOR itself, guy tried to overtake 3 of us at a corner, almost went head first into a semi, would have collected all of us... Twas early in the day, towards the end of the pack (obviously, me being in a N/A)
But f**k, I was driving so f**kin hard to try and keep up on that day!
THAT WAS ME! >.< Bloody bitch next to me was speeding up as I was trying to over take her... Twas rather frustrating... Especially being N/A :-( As for an incident, there was one overtaking incident on the GOR itself, guy tried to overtake 3 of us at a corner, almost went head first into a semi, would have collected all of us... Twas early in the day, towards the end of the pack (obviously, me being in a N/A) But f**k, I was driving so f**kin hard to try and keep up on that day!
lol i dont think i want to partake in the commo charity cruise anymore
Lol you know you need a faster car when you struggling to overtake a lady :P
I do not condone speeding, stay safe brahs
I remember going up to shepparton, birds saw this.
Alvin was overtaking some bogan in an old xr8, the dude stepped on it and we almost hit an oncoming car (car swerved into emergency lane)
This was in the soarer, and the soarer was missfiring because his pod fell off... LOL
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
    • And other times you just need to go buy bigger injectors?
    • Yup. I actually just blew my turbo. LOL.  should have checked this thread before today. i also have no boost solenoid. so it should be...one line from wastegate to turbo inlet, and a T somewhere in that line that connects to the wastegate return pipe?
    • It's recommended, however I can assure you a good amount of people don't bother. FWIW, the OEM battery lasted 4.5 years and I changed it prematurely too, I reckon could have stretched it to 5 years.
    • Are you telling me I'm going to need a code reader etc to just change the battery when it dies...  Why did I let you talk me into allowing Kate to buy this car lol
