how many men have you met, that you though were women?
ps you end up getting your 1.53 you were after?
If I believe the missus lots, when in Thailand she thought every second chick in a bar was a lady boy.
times nah, went out on last run and kept making stupid mistakes.
pushing too hard and locking whlle under brakes or running too wide.
pity got my highest trap times for the day and corner speeds were up so it's def there I just gotta find it.
was tossing up going out for the last run, but when the crash closed it, was done for the day
hahaha ladyboy.
yeh scott nearly got hit by an oldish blue wrx, as soon as those things touch grass they lose it.. probably missed him by a metre..
and the fact that there was GB oil all over the track didnt help, i spoke to the towie that picked him up. pretty stupid move by the driver continuing the drive half of the track spilling oil everywhere..
hahaha ladyboy.
Not that you were in the car or anything ey Aaron... :P
Bit scary having a rex crossed up in front of you, I nearly Tboned him. I guess he lost concentration having a Volvo whale pushing him. lol.
sent you a pm with his digits.
what did you think of it tony- your honest thoughts?
Thanks!
Of your car?
Felt like 270rwkw in a 1250kg car is more than enough for the street. I would be a bit scared driving that thing hard in the twisties.
It is a little laggy down low but I haven't driven that many sr20's so might actually be good in a sr20.
But once it hits full boost it goes hard!
Oh yeah you clutch isn't that bad lol, Did not stall once :P
The mufflers are around $400 as I remember, there are quite a few styles.
Can you drop in some time so I can have a look Tony?
Hrmm bit more exy than I thought
But I'll keep in touch with you Scotty if I do decide to go through with it :thumbsup:
not sure if you were still there, a wrx touched the grass coming on to the pit straight, lost it and went backwards into the wall hard.
lucky he had a cage.
I'm sure he had no idea he was dropping oil as he went past the pit entrance twice whilst it was happening!
It's worth it every time you press the quiet button on the remote. I can't believe how quiet mine is closed, almost stock noise level, not bad for a 3.5 inch muffler. Even open it's not too bad.
Thanks!
Of your car?
lol you didnt stall it because of the amount of pre warning i gave you..
yeh down low its abit meh, but once it comes on its all go.
yeh lol not that I was in the car or anything.
Yeh, we both saw that, I was hoping to get out for another run myself before that ruined my chances.
I love the way they let the Novice guys clean up the sawdust, it didn't seem to change the grip too much, just the confidence. :)
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
