15 bucks I think because there was money for 1st - 3rd. Just playing low money games for practise
Yeah I used to play the $3 or $6 tournaments all the time, used to win a fair few of em so the $ adds up pretty quickly, then I'd play some $11 ones...Kills some time
Yeah with the bigger player tourneys obviously don't win as much but when you do usually a good chance of winning big
anyone good with brakes here
ive removed old pads and the piston has come almost fully out
and i cant get the prick back in
even with the brake line undone and the bleed nipple undone
it still will not force back in
what the?
what the?
Sometimes they spin back in. Have you tried that? To get mine back in they need to be spun for the rear, but different brake setup. Worth a shot
how the fudge does that work?
the piston has a cross pattern on it
I used a g clamp and as you tighten the gclamp is spins the piston. Or is the piston shaped that it can't spin?
If it doesn't work you may have to pull apart the caliper
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
