Not sure, didn't have that problem when I got mine done...
Never saw this problem coming or myself. Googling I have found it is possibly possible that there is a 'silicon coating' and etc. I don't even know. I see on some tint forums this problem too maybe, people suggesting 00 steel wool or something. Ahhh Ceebs, why couldn't it just be tinted 2ez xD.
Saturday night 11 August, I might be doing a small gathering for Bday bbq and drinks.
Could also do a 'smallish' wastelanders food and drinks together on that night as well if there is a few up to it? And if Alvin wants to whip out some delicious food :P I'll pay for the food brah
i should be able to make it 11th.
i have 1.4kg of wagyu for slicing into hotpot thickness.
i can probably do one serve of singapore style chilli crab, of course, using mud crabs.
could also do some wagyu tataki. or something like that. can't think of anything else though, satay is too much work and requires a bbq grill. full 24 hours marination and shit.
Ease up lads
Is it a full month behind or they are just overdue on the pay date?
We reminder SMS at 1 day late letter at 3 SMS at 5 and so on
Can i interest you in our property management capabilities?
yeah full month, got paid for 2 weeks today but they were originally 6 weeks behind
went in and told them about it, they going to follow it up now anyway
In any case though Barry Plant are shit dream boats, instead of being paid monthly like requested its fortnightly, then every three weeks, then monthly, then fortnightly again
it's all over the shop :S
i prefer the Singaporean black pepper crab, was spicier and tasted better. Could have been where I went (don;t ask cause I don't remember :P)
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
