Yeh so you reccomend.. Is the car uncomfortable to drive with the mounts or as normal? Coz they aren't exactly solid they are just nismo poly urethane right?
Reason I wanted to as I saw it on the dyno and the motor moves a shit load, then Scott was trying tighten the wastegate and as he was pushing against it the whole motor moved. Don't know if fkd or just how it is but I didn't like it. How do you rate 'Megan' stuff? $250 +ship for engine and gearbox mounts, they are pretty much the nismo ones with a different brand stuck onto it
I used nismo so no idea on Megan, but vibration I did not notice any difference.
I only found pro's no cons.
and yeah they are a very very stiff mount not billet or anything thus "solid"
WIll prob get an engine dampener as well soon to make it a bit stiffer again!
less vibration = less wear in my books
You can have my damper if u want I can't use it because of the heat shield. Let me know if u wanna take it.
You will feel more vibrations on idle, if you are fine with that go the harder material. I'd prefer the factory mounts.
It's got a lumpy idle from cams, so if I can tolerate that I guess a little vibration shouldn't be anything IDE worry about
yeah but if the vibration is causing some plastic to rattle behind the dash or something, that would drive me insane lol
f*cking sick people getting me sick. Stay the f*ck home if you are sick. Got a holiday next weekend, i better not be crooked.... 9 days to get over a cold? Will be a close one...
Lol 9 days to get over a cold thats heaps man. 2-3 days is all you need
I did solid mounts all round. The revs determined which new part of the car rattled and at what volume. It also made bolts and screws undo themselves lol
Don't blame the sick people. I've been crook with the flu for two weeks and if I so much as dared to take a sick day (some days I've nearly collapsed at my desk) I'd be spoken to like I was doing the wrong thing and not setting a good example.
But 9 days, good luck. Hope you've got a good immune system, this one is nasty.
i had two bouts of flu/cough/sorethroat combo each about a week long and bad enough to give me shakes and night sweatswith about a week recovery in between. still coughing from the last one, and i leave for a bucks weekend on thursday.
lol yeh fair enough but not going full solid, jus polyurethane solid
f**king STOP IT!!!
lol its my iPhone, it automatically does it IDE never talk like that
hence why not going solid but solid
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
