They go well the Daytonas; people rave about them as a track bike. Triple cylinder torque is friendlier around town than the middleweight Japs.
Definitely one to test ride though; Charlie mentioned something about a high pitched whine at certain RPMs that is apparently normal for their engine...might piss you off after a while.
delicious. look at the marks on the tyre lol not sure if scrapeage or serious angle through corners...
thanks. would it be safe spraying clear on sections of tank with petrol inside? lol
and no i wasn't...?
lol only ever heard em on youtube. dont think they sound like japs think hondas probably the closest to an f1 car
Was just watching some vids of the cbr 600 on youtube, I rekin my mates 600 gixxer sounds more like an F1 car but audio quality on youtube isn't the best either....Will have to hear some in person before I make my choice
i'll only be test riding the 675 and a ducati 749 just to see what the ducs are like, will be going for whichever feels better i guess i don't mind noises too much lol
Wow that is a pretty ridiculous lineup. Htf do they fit all those bands? Still, the headliners of 2013 are favourite bands of mine, would go for Sum and Blink alone.
Yeah, this year was too good to miss.
They fitted them all in and almost over did it as after the first lineup, there were 2 more lineups released.
I am totally gonna see Blink 182 as I am yet to see'em.
Madball is a must and Dragon Force too!
yeah he must of man!
hes work on every car ive had over the last few years so i dunno if ill wait, go somewhere else or let the other guys there do it yet :P
I too always get Shane to work on my cars.
Mark's good at what he does too along with John too!
But I prefer Shane to be actually working on my car while Mark and John assist.
Is there any reason an R33 GTR bonnet won't fit my GTS-T? I'm guessing it's wider due to wider front guards?
Nah I'm pretty sure t fits.
As you said the cars wider because the guards are wider. I'm pretty sure the bonnets the same as the headlights are
pretty sure gtr bonnets fit series 1
Cheers. Found a couple of silver bonnets locally (don't want to get a bonnet posted), off of GTRs...my car will look a lot less like a golf ball if one is in good condition and fits. Then just have to get the roof dents pulled and presto.
Mate has one and it's a bucket... onto its 3rd diff, wheel bearings have gone, wheel studs nearly sheared off yesterday, more clunks and rattles than my r33
I'd go FG 6 turbo for same/similar money
haha Dan's car?
My cousin works at Ford and currently driven FG xr6T pretty sick cars, but still big to drive for me
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
