i cant remember that.
im pretty sure the mods started while on P's so there was no easy period.
although I dont know why I was scared, it was a wagon at the end of the day.
Edited by Sunkist
excellent, but the previous owner changed the mufflers so it has a terrible drone on the freeway (it's hard trying to source stock parts for an S2000). Probably the most fun I've had driving a car and certainly the most fun I've owned.
1) remove muffler
2) attach straightpipe
3) ????????
4) profit
That was the case with my Skyline, I have more boring plans for the S2000
not too tail happy in this weather? :P
Haven't had any trouble as of yet, it comes with 225s on the rear so they do okay in the wet. I've been very careful on corners and only hit vtec about 2-3 times because it hasn't stopped raining since I picked it up.
which is why I want to keep the exhaust stock :)
Future plans will be BBS LM, coilovers, front lip and spoiler. There isn't much point in performance mods with Hondas because you spend a lot of money and get little in return. Needs a new headunit too.
good ol' vtak :P
must be such a drain not being able to try stretch it's legs a bit after getting it due to the weather :/
although some rear squirmish action could always bring a smile to your face haha.
+1 induction noise though, prob sound cool on le honda
you have what i like to call, BBSitis, usually caused by hanging around roman for too long LOL
i came close to buying an s2000 too, i sort of regret it, and i sort of dont.
regret because they look so nice and go really well
dont regret because im not the smallest flamin mongrel, and id look hilarious in it.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
