Do like the r6 or r1 probably depends which is a better deal considering I wouldn't be riding on it's limits if I decide to go down that path anyway.
Just hate the r1 stock mufflers lol
If it's not about limits, I'd still be going the R1...all that extra torque around town for not much difference in price. You'll ditch the mufflers for Yoshis/Akras anyway. The only thing the R6 really has on it is better fuel economy and probably friendlier to the inexperienced when ridden on its limits.
Mate is in Japan for work...Tells me he's enjoying the food
So, where's good for Japanese here? We'll hit it up when he gets back
Tookaiya - Keilor Rd. Been going there regularly for 7-8 years.
I've been to places like Nobu, Koko etc etc... And they are really good as well... However for the price, you will not find better that Tookaiya as it's not a fancy joint, just good quality traditional style. Massive thumbs up.
hmm worth a try one of these days.
then again, looking at the menu, i'm suddenly not interested anymore. LOL.
Edited by xALmoN
there's lots of japanese cuisine.
it really depends on what you want to have. for sushi though, you can't go past suzuran @ camberwell, although they're takeaway only.
And then there are the izakaya sake bar style places where its kinda like a japanese style tapas place, and for that, i recommend maedaya.
And there's teppanyaki, which is pretty much a scam (LOL), i used to be a teppanyaki chef @ fuji teppanyaki, and tbh, dont go there, or any other teppanyaki restaurant for that matter.
And for hot food, you could try ash's recommendation, in fact, i will eventually go there to check it out, but i'm in no hurry.
Rode in my mates 360kw xr6 and then I jumped into a mate's 200kw EVO 8.
Xr6 was crazy quick, its a three speed trimatic and pretty much fried tyres in every gear. Quick but felt sluggish. EVO felt faster lol, is it the weight and torque?
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
