Ahhh welcome to the wasteland. Have to have another cruise soon when the weather is a bit more promising.
He was killed in the truck or by a truck?
Yeah not great weather for cruising, we should do Kinglake and surrounds sometime?
He was driving a truck and left the road.
Some good routes up there, I'd be up for it. However, of recent it's a known hotspot for the popo / yellow sticker people...so the more modified of us might not be so keen. Will have a chat with Tony and see what we can do.
Sad shit that, that you can be minding your own business without a worry in the world and in the next 10 seconds you're dead through no actions of your own.
These are the thoughts that bikelinesaustralia put up with everytime we ride.
That's what I said! Truck driver probably won't get anything either
So sad
Current brake set up is F242/Rdrums right. Should me buy brakes from vtec that are F262/R239 that'll be $500. Or wait out for Type R F282/R262 that will be 5lug (means have to buy new wheels/tyres) and would cost $1k for the brakes alone.
I wont be tracking this thing as of yet, but it'll be nice to get rid of the drums. Do some deca's ect.
Leaning towards the F262/R239 4x100. Which I can go pick up right nao.
take a lesson from all the old skyline owners here. Dont spend money on parts you dont need, Get out on the track/deca first and then decide what needs to be done.
Everyone falls into the trap of building track cars for a hypothetical track day sometime in the future.
Get out there now, find the limits with current setup, then replace to push the limit further.
So sad
if it was human error / fatigue i say put him away for 40 years cos that shits f**ked - shouldn't be able to wipe someone out and get away with it
This man, he knows.
Speaking of, Yoshi rearsets installed...darkness is spreading!
Can't wait for Pazzos to arrive :D
is it so hard to step 2 feet back then take the pic? :angry:
looks good. cover that bottle with something black so it's hidden
epic decision i made not to take out the bike today coz as soon as i got out of the driveway in the hilux it started hailing like a mafkr
Yup have a few guys asking when the next one is.
Will have to do one again, unfortunately got Winton & Haunted Hills coming up over the next 2 months, so just getting my car prepped for that.
But yes $2 Midnight Cheese and bacon rolls.
Haha I knew you'd say that...almost done.
Good call on the weather...deceiving shit.
can't wait til i am in le position in which i can afford both my car and a bike!
meanwhile in my current situation... coilpacks so expensive fffuu :P
You never win, when you are in le position there will always be more expensive things to get.
My r32 was better off when I was a student on casual wages. Now its all about budgeting & being serious with money :(
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
