Just go Shannons!
I was with Just Cars but this year they reduced my agreed value and up the premium.
Shannons gave me a cheaper premium and kept my higher agreed value from what Just Cars gave me last year.
how much they charge ruff..i like how you can choose your repairer unlike justcar
Yeah I might, a bit undecided. Means I might have to wash the car.
Haha!
You should be washing your car on a weekly basis!
$1300+
Yes, you can choose your repairer, that's right.
And if you want to pay monthly / quarterly / half yearly, they do not charge you extra.
Just Cars aren't as evil as the rap they're getting in here. All the insurance companies are putting their premiums up cause they all have massive offsets from hail damage - insurance is a business like any other, who else is gonna pay for all the claims? At least with JC you can throw away some of your premium in favour of a higher excess - if you're confident you won't crash then this pays itself off in 2-3 years of not having made a claim.
As for repairers, they will let you use your own if your quote comes to within a reasonable amount of theirs. There's nothing wrong with Just Cars repairers anyway...you can choose which one and they still have to repair a vehicle to your satisfaction, otherwise you are entitled to challenge it. To the contrary, when I was getting a car fixed, JC's assessor tried to get me to go with my repairer cause they offered to do it for cheaper lol...I said no, we'll go with yours instead (I preferred the way they said they would go about repairing)...so they let me...couldn't be happier with the job they did.
Last premium for the 33 was 847 full comp...I do expect it to go up a bit this year, but if it doubles I'll be switching to third party.
So many more options for imports these days; back when I was 18 there were only two companies who wanted anything to do with you. Shannon's would hang up the phone as soon as you said Skyline lol.
Haha!
$1300+
SOLD haha ill call up tomorrow for a quote.....#insert part where sunkist say "i told you so"#
lol so true I remember one useless one wouldn't cover you if your car was on street / unsecured parking at any time. So go Coles car stolen no cover.. No surprise they didn't last long
Hearing a bit about jdmst today.
Someone fill me in? Apparently a commo chucked a skid and someone thew a bottle at the cop car? Cops blocking entrances and the street?
Anyone went and see it unfold?
My mate got blamed for throwing the bottle at the cop car, but he's not the kind of person who would do that.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
