was good.
weather, cars, no issues(while I was there)
saw a supercharged 350z that was totalled the day before.
suprised at scott in the wagon pretty much smashing everyone else in his class lol
no idea.. was a yellow track edition.
guy came to pick it up and was still pretty devo..
looked like his daily too with the vic number plates and stock wheels. thing was completely totalled though the only thing not damaged was the passanger door and the roof - the car wouldnt even sit straight.. was such a waste!
Expendables 2 good shit but few fails
1. No Jackie Chan
2. JCVD not on the good side
3. Master badie not being the one and only Bolo Yeung
In other news, not bad weather. Pointless since you know by the time you get home you'll be too dead to go for a ride
nice.. goes to show you can still do some good times with a whale
what car was the 1:52?
motor mag did a 1:53 with a ford f6.. faster than what they did with evo 10 around PI which i find hard to believe
edit: better post some proof before I get flamed /fordsareshit:
https://docs.google....ZQNnlHS1E#gid=0
1. No Jackie Chan
Jackie chan never kills people in his movies. Wouldn't be a good fit for him haha
1. No Jackie Chan
If I go solo, I'm doin a song with Bolo
A big Chinese nigga, screamin "Kuniva yo yo"
Seeing it tomorrow night, pumped
why? freezing?
- VLINGO - it doesn't work and you can not turn it off unless you root the phone.
- freezing - more and more often
- touch screen - not working in some areas which read false touches
- kies software - soooooooooooooooooooooooooooooooooooooooo shit and crashes
- battery life now 1/2 day
and the main prob...
- the button... the only real button is now broken and registers a double tap when you press it once... this turns VLINGO on and the phone (EVEN WHEN VLINGO SWITCHED OFF AND THE PHONE IS ON SILENT) will loudly annouce:
"WHAT WOULD YOU LIKE TO DO?"
1. No Jackie Chan
It's very entertaining, agreed missing Chan but has a LOT of others in it. LOLed when chuck norris shows up..
Phillip Island it quite a fast track though
Woah thanks for the link! That's awesome
I was coincedently looking through all my old motor mags last weekend for track times done at Winton!
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
