If I go solo, I'm doin a song with Bolo
A big Chinese nigga, screamin "Kuniva yo yo"
In cahoots with this nigga named Carlisle Von, who got fired from UPS for tryna send you a bomb (special delivery!)
Phillip Island it quite a fast track though
Woah thanks for the link! That's awesome
I was coincedently looking through all my old motor mags last weekend for track times done at Winton!
yeah awesome database, agreed fast track but 1:43 around winton is still half decent
- VLINGO - it doesn't work and you can not turn it off unless you root the phone.
- freezing - more and more often
- touch screen - not working in some areas which read false touches
- kies software - soooooooooooooooooooooooooooooooooooooooo shit and crashes
- battery life now 1/2 day
and the main prob...
- the button... the only real button is now broken and registers a double tap when you press it once... this turns VLINGO on and the phone (EVEN WHEN VLINGO SWITCHED OFF AND THE PHONE IS ON SILENT) will loudly annouce:
"WHAT WOULD YOU LIKE TO DO?"
hahaha happened to me in lectures a few times. got into the habit of having a finger ready to cover the speaker. fkn hate kies too. Rooted the phone but im yet to install any ROMs on the bitch. Worth rooting for the Juice defender App. i think i was at 17hrs on battery and 35% last night before i charged. am at 6 hrs and 80% atm. this is with a good hour or so of solitaire and angry birds thrown in during my lecture
In other news, not bad weather. Pointless since you know by the time you get home you'll be too dead to go for a ride
Missin out man, just came back from one. Heaps of bikes on the mountain, it was beautiful.
Pazzo levers are so nice to brake with, feel like I can get on them harder and earlier. Clutch hand gets a bit more sore than normal...guess I'll get used to it.
I can't until the turbo is swapped. I'm thinking of just putting both up and saying if it doesnt sell in time I'll be "upgrading" to a tomei m8270 lol
Just edit the ad if you change turbos, ad won't expire until sold as long as you log in every 28 days
+ 1
Just put the ad, up then edit when you switch turbos.
Or just put up the ad advertising the tomei m8270 on it as is. And if anyone inspects it just say the turbo on it isn't included in the sale
There is a time limit?
not really, but would like to get in an evo sooner rather than later.
+ 1
might do the second, and say if you want the turbo it'l be more.
theres already a bit of interest from NS.com apparently words out that i want rid lol.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
