Still a daily, as I have no other car lol
Yeah will see how it goes when I install the turbo, May need to feed the throttle out of corners when I track it
I think you'll be fine with the invos for now, if the highflow is only going to get you 250 it should be alright with the boat!
Toby, arre you turning your car to RACECAR?
Yesp, slowly but surely..
SS2 brah. Probably 270-280rwkw apparently
you're azn, you'll never see his level...
what tyres ham's got?
Well at least he's got 'panaramic' / 'widescreen' view and can anticipate the track.
lol Jamie
lol... and isnt 280 a little too much?
I'm thinking maybe should have gotten the same turbo as Birdman. SS1PU
Iuno how you lose traction in 3rd, even with dunlop 245s in 2nd when they're warm I can pull 60km/h role and not lose traction if the road is smooth, if I take off from low speed in 2nd then it'll just spin tho
If tyres are cold or I havn't been fanging it around to warm them up it'll lose traction at 50-100 in 2nd feelsgoodman
Group buy nt05s gogogo
i'm planning on hitting nats in STD rwd.
did it last year and came 2nd to richo on the track..
so think got a decent chance this year.
but the airport run...i'm going to get demolished! what with my little 180 kw
how is your car so devoid of traction aaron?
even with 320rwkw I have full traction in third
You all drive heavy as f**k boats. If the tyres are warm I have traction. Just when everything's cold I don't. Plus the turbo is kind of nothing nothing nothing then bang 270
Probably also has something to do with not having it aligned yet
<3 SS1PU, so streetable! And happy to take the V8s above 100.
As soon as I sort out my fuel economy issues I'ma get that E85 tune for the super responsive 300!
This...comparing apples with oranges here. Even on the same cars traction is a totally different story with suspension setup and power delivery, let alone totally different chassis and gear ratios.
ya even with my power I could spin in 3rd when I had cold streets
semi's fixed that.
nt05s dont look very safe in the wet.
I did mt buller rd in the rain couple years back with NT05's and 280rwkw... barely saw below 5k rpm the whole way
they did VERY well
This... is what I was getting at..... ;)
    • You know the worst thing about acquiring more space for me? I tend to acquire more things to fill the space...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
