they dont touch me wagyu.
i dont have any now anyway.
i'm not fussed about them drinking it, its the fact that, when i go to the fridge for a can of coke, i find there's nothing left. no bloody initiative to replace the stuff they finish too. house meeting tonight, i love those sessions!
Lol crack the shits Alvin!
Who is actually head of the house?
Do people actually listen in these meetings?
I can imagine you saying all this stuff, but in their heads its like 'blah blah blah'
they will do what i want to shut me up, and start their nonsense again after awhile. and apparently it does work. one retard used to hoard all the bowls in his room. by hoard, i mean, unwashed plates and bowls were all in his room, he just kept using clean ones till there wasnt anything left in the cabinet. I cracked the shits once, he now washes them more promptly.
though he's a little slower on the uptake with regards to metal spoons and nonstick pans.
but as long as they replace my shit, problem solved.
and nobody is actually head of the house, but since i'm the only that actually does any real cleaning up, i feel i have the right to crack the shits. right?
Edited by xALmoN
Alvin: " hey you dik hed stop dlinkin my cok I wee kirr yuu"
Jason: "I ha' da flend who ha' da fellalli belly quik yu no"
What cop attention?
I never heard of it.
It's a knox thing.
Every time I booted the GTR I wait for 10 seconds after.. did i get pulled over? no? f**kyeah.
Alvin do you own forks? next time i'll BYO:p
It's a knox thing.
AHAHAHAAHAHAA. I do have forks. dw. next sesh isn't a chopstix sesh anyway.
Thank god! nah I'm not THAT bad with them it just requires far more effort and eventually I just cbf eating :P
Hahahahahhahahaha. I can imagine you getting pissed off at your food and eventually stabbing it with a chopstick
Yeh the horn. It's a 2 tone air horn. 140db measured 5 meters away. Fkn things made me deaf a few times..
See I want traction man, I don't have it until (sometimes) third and fourth, by then I'm going to fast to even use it on the street, let alone be able to put the first few gears down on a track
So you're buying a GTR next?
:D
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
