Cheers!
But wouldn't it bulge out too much?
Shouldn't too much. Dad has 245 on his ford, that's a bIt much lol
I drive a golf, you opinion is invalid for traction...... 205/40s it is then :P
Conformist lol
Out of stock! Just ordered 3 packs from US eBay on your recommendation. ~$25 delivered lol. Still pretty cheap if it does what it claims it does. Lots of people saying good things about it on the Internet.
Oh I didn't buy it through there, my colleague ordered off eBay. They definitely work. Wait half an hour after taking one, lie down in a completely dark room and you'll fall asleep pretty quickly and stay asleep. I was pretty sensitive to the 3mg dose at first and it made me feel hungover the next day but my body got pretty used to it and I'll wake up feeling awesome and refreshed. You might need to adjust your dose once you work out what your body needs. I probably take them once or twice a week when I know I'm going to have sleeping problems. It's a hormone your body naturally produces and it's shown to have a lot of positive health benefits, so in moderation it can't be bad for you. You can't buy them in Australia without a prescription, in the US you can buy them from the supermarket. No issues importing them though.
For the nights I cannot sleep at all Stilnox is the only answer, and it knocks me out cold. But I'll only take it as an absolute last resort.
Edited by llama_au
Yeah it sucks balls. Mine was hitting a ripple strip side-on and getting airborne. Expensive day - two tyres came off the rims (but thankfully were salvageable), scratched the rims up a little, stuffed a rear hub and put cracks in the front lip. The solenoids in the transmission also packed up shortly after. Think it ended up costing my about $1200 in repairs *sigh*
polished existing Slant lips. 17x9+20 all round with 225s
might run 15mm bolt ons all round
I would hope so, I'll be running 17x9 +22 on the golf rear :P
BBS club represent! Might also need some slight gaurd rolling although wheels are the same offset as already on and they don't rub at the mo. However need to mod exhaust to run a little lower so will have to look again. Tracking new lips and outers/bolts from Germany at the moment.
Quite oh my!
Is that the going rate for rolled guards these days?
Oh my.
Careful how much you order, customs usually take an interest as it requires a prescription in Aus
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
