cant, the rears would look silly as plus I need 19s because I'll be doing a 6pot brembo upgrade at some stage down the track
also, STRAYA KANT.
How much will this set you back?
How big are the rotors on your car out of curiosity?
I don't get the re agents and cocaine reference, but anyway I'm unashamedly a fan of iPhone and almost every business is working towards it and being compatible
Not hating on Samsung or whoever never tried it but as they say if it ain't broke don't fix it
I used to think phones were the best, even after putting up with it constantly crashing and it not syncing music like it's supposed to
Then I got an S3
Lol iphone.
So the s3 is good? Full review please. I'll consider buying your bike
Reading this right now.
Always find the Motor Tuner challenge intradasting
Sub $75k cateogry dominated by 86's and Golf's
Would have been more interesting if they did it on a bigger handling track. I.e. winton or something
They're the only reason I buy Motor otherwise I wouldn't bother buying/browse it at all.
86/BRZ and Golfs seems to be next budget 'Tuner' cars.
You can get a front brembo 6pot kit with braided lines and brackets for just a tad over 2k for my car
322mm stock rotors on the GS, brembo kit comes with 355mm rotors
Straight from a review of the GS:
Braking: With the same brakes as the XR8 (322mm and 302mm discs, sliding calipers), the 315kW GS is under-braked in our view, even as an entry model.
Feel through the pedal is soft, making it poorly matched to the ability of the engine. A shame, then, that the GT's four-piston Brembos are no longer an option on the GS.
Basically they didn't allow brembo factory upgrades because then you would be getting a GT for 15-20k less.. engine and everything else is the same only difference is the "315" and "335" tune which goes out the window anyway now that mines tuned to what? 440kw? lol
Then I got an S3
Lol iphone.
Was that 3? My 4 has been only phone to last me 2 years with zero problems I use my phone flat out to
fyp
LOL!
also, STRAYA KANT.
Agreed with the haters on iPhones.. all the f**king smart phones these days have big touch screens, take photos and have 'apps' zomg soooo different!! apple is too mainstream? I don't care because my car has integrated iPhone connectivity so I can have everything display on my screen in the car and use steering wheel to change tracks etc. If I had an Android I'd have to plug it into the 'AUX' connection and use the phone itself to change tracks.. that alone is enough for me to go Apple really.
And same as what Alvin said with the Ipad wifi model, just use my phone for reception if I'm out and abut.
Oh and Hamish you're right about the customer service / replacement phones, pretty good. I used them a fair bit at my old work.
Stick to ya Bob Jane wheels :rofl: STRAYA KANT
Android for the fucking win! KANT!
That actually seems quite cheap
link?
Newsagent brah
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
