Lucky bastard, so how did you get into that did you study programming? develop software or??
I has year 12 only...
started uni, Chem eng, hated uni with a passion due to having no Fkn idea what I wanted at the end.
I just did what ppl said, oh you has good results u should do blah.
I grew up on a farm no idea what the options out there was.
so thrown out of uni as I was bored, I got a job for a telco help desk in fact a couple desks up from paul33
did well, went to work for a dot com start up..showed some skills blah blah blah travel lots
so I would like to say self made..
LOL man my 1800kg boat ain't designed for corners :P
STRAYA !
f**k I hope not as I will be going head to head with you!
aight, should give me some what of an indication just imagine 1cm off on each.. when can i try? :P wish they were 19s!
Alvin's! Aren't u after some grip? Surely you'll have more with 18s it'll definitely be cheaper aswell
ah okay cool cool, I studied I.T for 2 years after year 12 been in the workforce for about 2.5 just wondering about career paths down the track.. hard to think of many things other than infastructure management / i.t manager stuff :\
ATM just server / desktop / app support type roles..
Don't worry won't be taking my whale on the track you'll be up against me on the 1/4 mile tho
I took your advice, have had red meat for the past 4 days. I feel f**king fantabulous. Maybe take your own advice..
Watch now Ive jinxed it
Been hitting up the Vitamin C + water + good sleep too?
My advice probably works well for other people, but because I have next to no body fat and keep sharing beds with people who STEAL THE BLANKETS, causing me to wake up shivering...my advice will only take me so far :(
re work...right place right time, right skill set. I was a lucky prick end of story.
been one company for 12 years next week. started bottom level support
talked my way up since then.
i've worked hard but been rewarded such as well so no complaints
re track.
I would be keen to see it go round...(more would love someone give me some keys to take one round.)
i recon I could give run for your money on a track...straight line...i'm doomed against not just you...so many cars.
Yeh water and sleep is good! Happening a lot more since I been eating well. Also got on this stuff called orange triad by controlled labs.. Immune joint digestive system multi vit. Took it for the first time this morning just one to see if I'm gonna react. So far so good..
I'd probably get half a lap in with the current brake setup :P not taking it on the track just yet need a few more things setup before I give it a go. Would be fun sliding it around though!
Just airport / show and shine this year for me
Wrapped roof looks poo, me no likey. I am happy with how the car is now, could use a front lip of some sort.
Off to Japan next weekend. Shopping list includes, cusco lower control arms, nicer foglight globes, Carbing strut brace and anything else I impulse buy
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
