really? I never tried because I was told they're a shit version of Pancakes....
i'll take pancakes over waffles
but if you cannot have pancakes waffles are cool
but anything I can put maple syrup on I'm a fan of
haah nah the grills alone are going to be costing upwards of 8k each i believe :)
It's not being done on the cheap
Check out somewhere like Pete's Bargain Centre. They used to get heaps of new, used and surplus kitchen equipment, etc. in. My ex's restaurant bought loads of second hand tables and chairs previously from Crown Casino there. They also bought all the wok burners, kitchen benches, etc. brand new from there very cheaply.
http://www.petesbargains.com.au/
Tried to get a test drive of the Toyota 86, failed.
Dealer want me to lay a deposit and be prepared to wait for 18-24 months for 30 grand Toyota, no thanks.
Nunawading Toyota? They declined my a test drive without a $2000 deposit and intent to purchase. The other dealers were all happy to offer me a test drive but no GTS available so I declined. Test drove a BRZ instead, weighed up the decision and the BRZ won for me.
Bingo, they demanded a deposit, who was the salesman?
I gotta ask, is it really that good to drive that 86/BRZ thing?
Haha, I knew it! Pushy to the point of being downright rude. They definitely turned away a potential customer. The guy's name was Ben. That night I laid down a deposit for the BRZ.
And yes, they are that good. Go to Subaru Docklands and test drive a BRZ. I wouldn't get a GT, but a GTS or BRZ will just be a personal choice. The interior, exterior and free servicing won the Subie over to me. The BRZ looks a bit classier, more refined and less boy-racer. Plus WRC Blue Mica is such a nice colour and you can only get it on the BRZ. I think resale is going to be better too.
dont go into the shop knowing what you want though, try them all on and get what feels best when shopping for helmets
My only requirement was a helmet :D didn't find one I could get my glasses into. Will have to try some more stores, but work is apparently not near anything and left it too late this weekend.
Pretty sure BRZ is closer to 40 same as 86 GTS.
86 GT is 33k driveaway, I've been quoted.
My biggest issue is will I 'live' with something is as powerful as my brothers Commodore - coming from string of Skylines, I don't think so plus I'm not prepared to wait forever for one.
got mine from peter stevens in CBD.
service was shit, but they had the range I needed to try things out.
arn't they closer to 40 on road grant?
or is toyota cheaper?
I optioned out my BRZ 6AT with Premium Pack (leather/alacantra heated seats), a rear diffuser and floor mats and came out at $42,225 including all on-roads. The equivilent GTS would have worked out a touch more expensive but would have had sat nav which I gave no f*cks for. And 3 years/60,000km free servicing on the BRZ ftw.
get in your delorean drop back 6 years...hit up deca..
or...maybe they will come back at the next deca I'm not racing at.
Someone please promise me that there will be wangy burger at deca in december???
Must suss this wangy thing out!
Same bloke I met today, he told me the power of 86 is 170kw when it's in fact 147kw...
Not sure if I'm prepared to stretch more for BRZ but given there's 13 months wait, I suppose I could save up a bit by then.
If all you want is a GT you can get one reasonably quickly provided you're not picky about colour. There's surplus at dealer because far less people want the GT. The manual GTS is where the huge wait lies, and the BRZ is starting to blow out as well.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
