Nice! Cusco, TRD and Beatrush have lots of nice braces available. Whereabouts are you going in Japan? If you're in Tokyo visit Super Autobacs Tokyo Bay and head up to the bookshop. They should have plenty of 86 magazines :)
Looking at the Carbing strut braces, but just found the price of the one I wanted to be 65,000 yen. I guess titanium is expensive.
I'll be getting Cusco camber arms, a few sets of wheel nuts, random hello kitty items haha.
Yeah exactly. Not going to bother advertising it until I have a confirmed production date for my BRZ. The Cube almost costs nothing to run. I fill up with $50 worth of 98 Octane probably every 6 weeks and it's reliable as anything.
nice, i love the cubes
Might try waffles next weekend.. I didn't know what blue waffle is, so looked it up.
f**k you guys
I forgot what it was and just looked it up too...... just been assuming that it's waffle but different flavour.. freakin ewwww~
f**k you guys
success!
f**k you guys
bahahahahaha pwnt
18x10 +38 nick :P
yours should be this low!
why?... that looks as gay as two guys open mouth kissing
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
