man vs food...
burrito chalange (in knoxville)
burrito:
2 lbs pulled pork (900g)
1 lbs beans (450g)
1 lbs coleslaw (450g)
1/2 lbs cheese (220g)
4 full size tortilla
sides:
1/2 lbs mac'n'cheese (220g)
1/2 lbs bananna pudding (220g)
1 hour
that's a total of just over 5lbs (2.25kg)
never before complete (adam richmond was aparently the first to manage)
how ya reckon ya'd go dezz?
i reckon i could do it
It's disgusting but good show that.
They're not arriving :(
Seller canceled transaction on me cause out of stock. Everyone seems out of stock, wtf.
I've got 200x 5mg coming in, you want half of them? I'm fine with half that dose so I'll be cutting mine in half.
Bought a doberman puppy yesterday, won't be ready to come home till mid October, can't wait!
Pics when you can pick up him/her!
My dawg turned 1 last week, and he's still a rascal!
No need to project your own interests on to me, man! :whistling:
What would you suggest?
I'm no beer connoisseur though, just a simple guy, I just like what I like. Coronas, kirin, asahi, stellas, pure blondes, all good stuff imo. :yes:
generally speaking these are the cases i buy (i go through about 1 - 1.5 a week)
tiger
tsingtao
heineken (import only)
pacifico clara
cricketers arms
brooklyn larger
weihenstephaner krystal
erdinger krystal
yelkopopoviky kozel
wingwalker pale ale
murray's whale ale
kirin ichiban (japanese one only)
kronenberg (import)
bintang just makes me think of wanker straya kunt types wearing a bintabg tanktop in some form of desperate attempt to let people know they have been to indonesia
as grant said...
augustinerbrau helles = best beer ever
only available in bavaria tho :'(
Which is very upsetting.
Time to save up for another europe trip... Or a trip to America.
tiger
tsingtao
pacifico clara
cricketers arms
brooklyn larger
erdinger krystal
yelkopopoviky kozel
wingwalker pale ale
murray's whale ale
kronenberg (import)
Pfft you call those beers?
All I see is a list of water downed pilsners and pale ales :P
Get some scotch, dark, brown ales into you or IPA's if you like hops.
Lot of great micro breweries in Australia. No need to buy into the marketing of overseas companies.
Grand ridge, mornington brewery, white rabbit, Matilda bay etc
*all comments made tounge in cheek. Drink what ever the f*ck you want.
i can probably get it on the d/l but only in kegs and it will be expensive as aids medication
So it'd be cheaper for me to go to Germany and drink to my hearts content...
i f**king HATE 99% of Australian micro brewery beers....
they are all trying do over hopped IPA's and they just taste like a bunch of flowers (and all exactly the same with VERY few exceptions)
if anyone is falling to the trap of marketing (or attempting to look like there is no marketing) it's people that pay $70/case for aussie microbrewery beer ;)
want a heavier beer... hit up a 750 of chimay grand cru or a duval ;)
edit: to take a lil swing at pat :P
Edited by joeyjoejoejuniorshabadoo
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
