wrx is basically an underpowered evo with a weaker gearbox and higher percentage of cars with mini boxing gloves hanging from the rear view mirror
I lol'd because the last WRX we had in at former place of employment had the gloves lol. What the f**k is with that.
I've got 200x 5mg coming in, you want half of them? I'm fine with half that dose so I'll be cutting mine in half.
That's really generous, I think I'll take you up on that. Just lemme know when / how much I owe you and I'll drop past, cheers :)
try this guy, these are where I got mine and they came in pretty fast too, not sure if that cheap compared to where your looking but they have stock at least
Tried it last night and works great :)
http://www.ebay.com.au/itm/320862768874?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_1661wt_1163
Thanks! I'll add to favourites for a future order.
What do people think of wrx? I inspected one for a friend yesterday and was actually quite impressed and are in the same price range for an evo. What u dream boats think
Guy I worked with at honda had a new wrx sti - went through kinglake twists and to be honest that thing just stuck to the road, I was actually really impressed
true, but still... evo > sti
WRX drive well and make a decent daily compromise for a sports car...definitely felt more comfortable putting around in one than my Skyline. I was surprised how well it pulled for a 2 litre engine too. But...bit of a boring vehicle in a stock configuration. They aren't really pretty inside or out and they're pretty old hat now, like Skylines.
Wonder how long the "Evos are the shit" buzz will last on the import scene.
yeh i dont know whats happening with the car now.
after going for a spin in thats wrx yesterday i was very impressed - but supposedly $90k spent on it.
after driving an evo stock, i was still fkn impressed at how comfortably quick they are. good daily
ive found a few evo's i want, but now realising that i will probably regret getting a four door if its not an evo... seeing as a company car will(should) be around soon.
which then leaves me to, is there a point in selling mine? or do i still want a "change"
33GTR's are starting to catch my eye aswell..
my mind is full of f**k
Keep your car and track it pusssayyyy!
Otherwise Evo or 33R
Post links to the Evos your looking at brah
the evo is on sau..
white evo 8
33gtr havnt really looked, just liking them more and more..
Drove one ages ago, wasn't that impressed, only nice thing is boost comes in early but there's nothing on top end, that's it.
Want 300kw plus? Replace essentially everything, f**k that!
Mohomo, lower it more.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
