What do you do for a job, again?
no idea..but damn it fun..
decided ahd to have a holiday b4 they send me to Bangkok
I'm stuck in a climate controlled factory with no windows. It could be the apocalypse outside and would not see/ or feel it. And any chance for stepping out during a break isn't possible as I'm wearing factory uniform :(
know that feeling, when in the office in melb I'm in a white room, cameras everywhere and no contact to the outside work.
need to reference BOM to work out what to wear to lunch.
Travels the world, works in top secret laboratory. Sounds like you planning on taking over the world.
Dumb bitch in a white Celica changes lanes in front of me without indicating as we approach a red light. So I change into the lane she was originally in, we both end up in pole position. I see her talking to her passenger like a drop kick, not watching the lights...lights go green...I take off sedately. She catches up and yells out "let's go bro" in imitation wog accent and then puts her foot to the floor. Then a few car lengths ahead she sticks her hand out the window to either wave in victory or flip me off.
I don't want her to live on this planet anymore.
Gym brahs what's a good superset for shoulders? I got decent individual excersices for em but want to push to superset thinking something to go with the smith machine press
Suggestions pls.
Push ups work well as a superset item because you can do them anywhere. But supersets aren't really necessary if you're working your shoulders properly, unless you're trying to get quick workouts and save time. What does your current workout routine look like?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
