Agreed, and it shits on all previous GTR's I've had even though it's bit slower than my 1st - could be used to power too quickly but I can always re-tune it for moar killerwasps :D
When you've got a stock exhaust and it's not tuned for it and it feels slower than my stock GTS-T, you can't say that just yet :P
He's already agreed to sell it to me in a year or two though so it'll stay in the SAU family.
Specs on the GTR..?
Care to elaborate grant since youve owned quite a few 33r`s lol?
The condition of the car im assuming? How about the way it drives? Similar but different powah?
Yep, for the condition of the car alone, plus it's Series 3!!! I'm yet to put the coilovers and exhaust in yet, but I'm into it, I'm sure it'll drive differently to previous R's
1st GTR had 302rwkw with GT-SS/-9s which is my favourite combo (was going to buy another R to do same combo until this one popped up).
2nd GTR, had 270rwkw apparently with 34 N1/-7s, thing is it was tuned really shite, misfiring like crazy, having issues starting both cold and warm etc, won't go into detail there...
3rd GTR is basically stock with just pods, exhaust, only awesome thing about this R is these Panasports.
Yeah, yeah, yeah, and it isn't loud enough yet... But apparently stock exhaust does make a little racket judging the reactions I've had from 'general' public whilst driving around.
Did I just do that?
Wow, that was fast :P
Specs on the GTR..?
34 N1/-7s
Sard 600cc
PFC
E-boost street
Exhaust (front pipe, cat, cat back, the usual)
Organic clutch - want to replace it with twin or triple plate.
270rwkw @ 18psi or thereabouts.
HKS coilovers - not installed yet.
Work Emotion XD9 in 18x10 +18 - I'd like to get different wheels.
34 N1/-7s
Sard 600cc
PFC
E-boost street
Descent streeter.
What clutch and wheels you want?
Any further plans?
Would like a os triple plate, as for wheels, I haven't decided yet.
Any plans is either to drive it or milking more power out of this setup, I'll see how I feel about driving around more with -7s.
Panasport G7...
Haha!
Aaron you do know what has to be rubbed all the way back and recoated in primer yeah?
textas bleed through it.
the panel beater just told him, but apparently is his cousin and was sanding back the whole panel anyway.. So he said dont worry about it..
Since when is Mohsen ever right and to be in a situation to make others aware?
They grow up so quickly!
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
