lol wipers aren't working. Doesnt matter if the engine pops 1 minute after rego transfer, you're in the clear.
This is what mechanical inspections and roadworthies are for. Tell him to take it up with whoever he did (or didn't) get to inspect the car, or the RWC workshop.
Cashed my points in for $230
Considering I'd never paid a cent of interest at that point, it wasn't a bad deal
I like my BankWest Breeze Mastercard - low interest and 5% cashback on all 'daily living purchases' such as Coles, Shell, etc. some months I get ~$50 cash for just using my credit card although I'm not sure they're offering that deal anymore to new users: http://www.bankwest.com.au/personal/credit-cards/compare-credit-cards/breeze-mastercard-low-rate-credit-cards
Never paid a cent of interest as I always pay it back before the due date :)
First night on melatonin @ 2.5mg (half tablet)...so far so good. Vivid dreams (got caught touching myself in public, wtf); still woke up a couple of times in the early hours of the morning; don't feel as tired as I normally do, could be placebo. More testing required.
I tend to get more dreams on them too, or at least, dreams I wake up and remember.
Yeah for worst case scenario I've got a couple of 5mg Valium here to knock me right out.... But wouldn't be taking the whole thing
I was only taking 1mg in Thailand and those knock you out pretty good anyway
I wish Valium knocked me out, little to no effect. Benzodiazepam-based sleeping tablets don't work on me - I've taken 4 in one day after 3 days of no sleep - no effect. I ended up walking around Times Square New York at 4am eating Pizza after taking them lol. Stilnox on the other hand - miracle worker. It knocks me out cold. I've managed to make the packet of 14 (they limit supply massively) last probably a good 4-5 months, just getting to the end now. Had to take one last night as I had my usual Sunday night unable to sleep after two long sleeps in a row. The only side effects I get are a very dull headache all day - like I've had all today. Panadol gets rid of that. Melatonin usually gets me by during the week, and then I take a break and sleep without it Friday/Saturday as my body knows there's generally nothing to wake up for/be anxious about the next morning.
Edited by llama_au
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
