yeah, cos a 360awkw bought not built GTR is not a cheater car but an evo is :P
lol good thing when i purchased the GTR it didn't have 360rwkw then isn't it? :merli:
It also didn't have brakes, suspension, diff x2, larger turbos, ECU, injectors and that's just what i can remember :D
Basically just as i had it as i wanted, you got it
:laugh:
Haha true,I wouldn't have done anything much differently. Only difference, It's just gonna be really really shiny when it's all done :) Been thinking a lot about e85, will see what happens
And a big single...haha
well then im sold on a 7.. not going to go nutz on mods, so dont really need the stronger engine!
and if it does blow up.
stroker.
2.4 stroker are cheaper to build than the 2l lol
Only thing is the 2li is more rev happy
Regarding evo 8 MR, I might be wrong but don't they have different cams to normal evo 8's. I'm sure iv read it somewhere when I was looking into them, could be wrong tho.
Yes they do, but cams are upgraded usually to, especially if you do upgrade turbo
So again, 8mr is really more money for something that has an alloy roof and fancy CF rear spoiler if you plan on modding the car (which you usually will with an evo)
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
