Credit card - then do balance transfer to low interest credit card transfer deal
e.g. http://www.citibank.com.au/aus/credit_cards/cards_platinum.htm
Just don't use the card for anything else. Shop around for other deals though, the citibank card has a $250 a year fee
Still can't believe they offered one once with 3.99 for the life of the transfer
Would a Victorian unregistered vehicle permit be valid in nsw? So I can drive my car from the hotel to the show n shine
Also remember a unreg permit is meant to be only for getting things done to register your car.
So if you get pulled over up the Hume, you will have a lot of explaining to do, and if not sufficient permit goes and you call a tow truck.
Hambo - 2 days this week doing 6hr shifts in a kitchen - knocked the stuffing outta me, but must admit I'm highly enjoying it.
Will get used to it in a few weeks no doubt.
Cant wait to get open!
hahaha so in total you did 1 average day (well only if there was no break) ;)
opening you own place you will probably end up doing 80-100 hrs a week untill it's making cash back. EOTD every 40/w you d is 50k a year that you aren't paying somone else to do it .
we still need to have that drink... you free this week?
Got a 10k limit on my credit card... But think for cash advances the interest rate is stupid high...Don't know coz I've never used cash advance.
Might be an option considering most personal loans charge a fee if u pay it off within the first 12 months...
Hamish & Andy, insider opinion?
Personal loan is the safest option.
atm westpac are offering a 12.9% from memory.
dont go the cash out then balance transfer method, as you will then have 3 x enquires on your veda report within a year and the balance transfer might get knocked back.
what is the story with your homeloan? is there an interest only portion? cos if there is i'd be staying away from excess credit until this is over as the loan will be reviewed at when it reverts to principle and interest.
personal loan is the safest option if a 5k redraw is not available to you.
just remember that every redraw will be visibale to a banker when you wish to restructure the product, and as such you always want to keep this at a minimum.
with a credit card you have to be more vigilant and make sure the payments are made on time, not early, not late and if you pay just the minimums on 5k you will be paying that for approx 15 years, whereas a personal loan will be 5-7
yes they are, on their flexi loan til the end of the year
He already has the CC though, so should be one less? Probably my circumstances, but never had any issues with my report to date.
Yeah, fkers, late fee for paying early :-/
It's not a late fee for paying early, it's because interest is calculated monthly, so if you pay early then your payment will count towards the previous month and technically you haven't paid the current month... Jus made a double pay for the previous month.
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
