yeh i registered.. some strange requirements, but atleast it means the likes of NS will be there ...
Indeed... I tried twice, but got an error though :/
Although I did put my lisc. number as 000000000. But the error seemed immaterial to that, so I dunno :/
Such as?
Location (City, State), first name (no initials), car make, drivers license number; must make a non-one-line decent introductory post in intro section before rest of forums can be seen.
Those seem to be it from what I can gather so far. On the one hand, I see where they're coming from, and didn't really mind, but driver's license seemed a bit excessive / I was surprised lols.
Edited by kaitoukid
Seriously?
All that for a godamn forum?
the cressida ones are even better man...
those dudes even have a fake forum with topics about pension money etc set up until you are verified as a member
LOL hahaha
yeah then admin has to approve your registration i'm pretty sure I had to wait like a week for my evo oz account..
Yeah had a feeling prob need admin/mod approval for reg... thought they'd be a bit quicker than one week though. But still... dat security.
Seriously?
Mmhm.
Maybe it's great once you're in though hahah.
wow I signed up when they first got started so they have none of that for me..
I personally would not be handing that info out over the web.
DOB drivers lice suburb..great for identity theft, hope their DB is secure
Yeah that's why I wanted to sign up - lurk and just gain more knowledge in general.
Haha like I said earlier, not too fussed about some things, but yeah stuff like license I was a bit iffy :/
If 000000000 too obvious, maybe just make up some random 9 digit number :P
Yeah, I'm getting some other unrelated error as I first thought.
"Error: ! Anonymous hit limit reached for IP Address xxx.xxx.xxx.xxx.
Why not get an API key? It's free, and it'll allow you to perform a larger number of bot-screening lookups each day.
If you aren't the webmaster for this domain, please tell them about this error message."
Tried resetting my IP to no avail.
Ceebs. More procrastinating instead of studying for exams lols.
Pics?
check fb all there
Well they can't hand out defects for phaggotry
LOL
They were probably in disbelief of the shit that they do to their cars
hahaha yeh..
be funny if they did..
hey nick;
why is it that all the dump pipes for evo's are only 2.5" exit.
isnt that a tad small ? how are these people hitting over 250kw with it?
Zage dumps are the biggest separate dumps, some aren't even 2.5"
Custom is the only way to go anything bigger than 2.5, I was running a Zage no problems.
http://www.ebay.com.au/itm/Turbo-Dump-Pipe-Mitsubishi-4G63T-Lancer-EVO-7-9-Outlet-/281016580474?pt=AU_Car_Parts_Accessories&hash=item416de4b97a&_uhb=1#ht_2015wt_1397
These are Zage ones... Buy here for $15 compared to $300 from Meek
You can go a MAP Performance split dump front pipe, but it is an absolute headcase of a fitting, it's hard enough getting the dump off with the rear nut
The link I posted is the best way to go, unless you go custom 3" dump which for the power your chasing is no point
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
