Awesome. I found a HPI combo dump and front pipe for $650 which is a 2.75" out dump to 3" front pipe. Reasonable?
I've just heard the stock system can choke and strain the standard turbo and after time it'll fail(myth?)Would like to avoid a blown turbo atleast until I decide to do the MR turbo..
Apparently yeh.. The stocker can hit 220. Unaware of whether its a ceramic wheel though.
Ill still be keeping it stock. Just a bit worried as its cheaper to do an exhaust, then getting bits of turbo out of your engine if it blows
Yeah I would avoid the combo ones if they are one piece, my mate got a MAP 1 piece and its a pain in the arse to take off and put on
I'd get two separate pieces myself
do you even need to do the MR turbo
aparently the stocker can hit 220 odd
yeah that's at its max, the MR only has a larger turbine housing and the 9 has larger comp and turbine housing
Not ceramic, and won't really damage anything but you will notice a lot more response mostly from upgrading them, as well as power
8MR turbos are cheap, I picked one up for $350 delivered from the US
Yeh was trying real hard to justify it lol.
Nah the combo was a two piece that deletes the need for that gay spring setup on the dump. Looked fairly cheap for what it is. I think making up a custom dump would be too hard. But I'd rather leave this turbs on for a long while.. If I upgrade the turbo it will only be if I build the motor, and it will be a gt30 lol
Oh yeah. The spring thing isn't so bad though, will never leak with how tight it always stays
If you can find a cheap mr turbo for time being, chuck it on when you do dump front. Will have so much more fun
Speak to that Frank guy on TC, he seems to know Hondas. Always says you can't go wrong with 08 onwards for the blades
went past today, it's gone :closedeyes:
twas actually an '06 with 16000ks
sold for $8k ride away
so i picked up some cf mirrors instead
Doesn't sound like a very good price...
Tell me you didn't buy CF mirrors for the bike you're trying to get rid of...
