Fk that's so lame I'm all for getting knobs off the road but far out such persecution would be outrageous if applied to other socially accepted entertainment but nope nobody minds the fact you can't go for a drive legally!
Could I sell a 'item' on eBay and purchase with another account pay with credit card / PayPal then get that transferred to my normal savings account to avoid any cash advance fees with the credit card (1.75%)? Or am I over thinking things (basically a couple of grand on card to buy something from a private seller)
Yeah just checked 1.1% to 2.4% + $0.30 AUD to get payment with paypal, ah well 1.75% isn't that much I guess to do it the normal way :P Just really want a motorbike but trying to hold off until next month!
What bike?
Yeah alot of innocent bystanders caught up. Everyone is just outside sitting out of their cars as there is nowhere to go and would be a a few hours. There was a bus full of passengers too!
toby do this to yours brah
Nah brah
Circuit racing!
Any suggestions for car alarms? I wanna spend under $200 for the alarm itself, was thinking along the lines of Mongoose M60G or M20S for something a little cheaper (already had M20S in the past and it was great). Any suggestions?
alarms - get something simple man
i paid a heap for viper 5701 and a tilt sensor, remote start and all this stuff - a few weeks ago in the city im under the bonnet with a box cutter cutting it out cos the f**king siren wont turn off, alarm goes off by itself randomly also..
thank god it has a lifetime warranty, so gonna get that shit sorted asap..
Yep I'm definitely thinking something simple, just needs a good install and an easy to use remote and I'll be happy.
I bought a mongoose M60, doesnt go off for no reason, inbuilt turbo timer, 30 sec to start car from unlocking, only issue is the beep is so loud... but that was $400 fitted.
I think I'm gonna go with the M20S, had it in my first car a few years ago and loved it, very simple and no annoying sounds, hopefully be able to get the autoelec across the road from work to install it... might get it a bit cheaper (yeah right..)
Edited by Borci88
Better wait til next month then, sports bikes might be back on top :D
haha maybe, problem is if I got a sports bike I'd want full comp which is $$ and with the motard if I drop it at the island or something just pick it back up and it's sweet and won't have to fork out 4k for making a mistake on the track lol plus after gym I can just ride up over the grassy knoll and hop on the bike track :D
always fun trolling some of the sports bikes too with the gearing / weight a motard has :D but you're right sports bikes look the sex not really too fussed about outright speed got the car for that stuff too
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
