anthony bourdain has said that no matter where he goes in the world, and no matter what he eats, the only people that ever get sick on his crew are the ones that eat at the hotel buffets
All you can eat / buffet = bad idea no matter what the situation
you are just ASKING to get sick - if not food poisining/gastro, at least cold/flu etc
I've been going all my life
Must be immune to it by now :P
Where is this mysterious place you speak of?
What did you order? I don't think it's anything special, just very yank and a guaranteed fill up.
Forked pickups for my rear stand
dezzmann, make it to huxtaburger yet?
Nope. Burger tour stalled after 3 joints... gotta get back on track.
This. I don't trust food in general from an all you can eat place let alone seafood. If the buffet is <$60 a head I won't eat there.
Never been sick from.a buffet... if it's a popular/busy one chances are everything is fresh.
Mate at work told me to hit the conservatory buffet at crown
~$100 all you can eat with steak and seafood etc. Will hit
lol guy gets sent to jail for 120days for calling a judge a c**ksucker
From 2mins onwards
http://youtu.be/goTVyb8qO6s
woah!
IMHO that is pathetic on behalf of the judge, yeah the guy is a know and should have shut up, but a judge that is that far up his own ass and that fragile about being insulted should not be a judge
a judge is supposed to remain objective at all times, and that guy clearly not able to keep his emotions out of a descision
remember in a buffet, it's not just the food/chefs that can make you sick, it's how long shit sits there, and the people that are eating at the buffet.
some guy takes a dump and doesn't wash his hands, touches all the food and BAM.
not to mention you have lazy waitstaff deciding when things need to be returned to the kitchen and sometimes topping things up.
I 100% guarantee they will just put new shit on top of old, leaving rotten food there just waiting to attack someone.
I have worked with 100's of waiters over the years and I can guarantee they don't give a shit about anything to do with the kitchen.
Waitiers care about 3 things... tips, free food and free alcohol
fb informs me ftg and stud road corner is having a wonderful epa/defect station! just in case *awares*
in other news...
loving lying around at home today :D.
Might drive through it for a laugh
http://actionshotcam.../news-and-blog/
$50 from Kmart.... anyone gain to be the guinea pig and try it out???
looks like an ok (cheap) alternative to the gopro white...
ill stick with my Black.. i cannot wait to get it.
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
