Ditto. You just said you hated looking for second hand, and you want an Evo. Hence..
If you do find one though, look for rust. Look everywhere for rust. Not only on the rail, but in the wheel arches, and under the plastic bits. About 3 that I looked at were covered in rust, but I didn't find it until I was told where to look.
Look for ayc issues, oil level and lights etc.
Transfer case is a common leak as is the oil sump seal and the rocker cover seal is too..
Standard suspension usually leaks and knocks too.
To see if things have been changed in the engine bay, the original bolts have number 7 on the top.
Things I was told anyway
thanks for that man...
before i buy i'm gonna get a full inspection... probably from techsport or state roads.
I looked at one that was just out of my range that had a techsport inspection and i was impressed
this is why i am thinking of importing... can just give IM the $$$ and not spend my weekends looking at cars as it annoys me.
also, i know i might not save any $$$ or time, but in the end I will only ever have this time with my baby once and it's priceless
need to call aaron and have a better chat about it all
Yeh I had it inspected by two mechanics and sent racv to his house. He was rather pissed that I kept sending him everywhere lmao. But I was buying a car I wanted to make sure I was buying something good.
Speak to Aaron, or even northshore prestige in Sydney. Northshore is f**kig insane for quality, asked a few people to do inspections and they all said no need, the cars are 110% of the time perfect.
Lol, did you dance for them?
no
Rode to work today, no one looked at me
how do you carry your tools? :huh:
Awesome day on the spur, can't ask for better weather.
Few f**khead cars crossing over the lines, but what can you do...
do any of those mirrors work or is it just mine that are useless? always have to turn on the bike to look behind/blind spots might aswell take em off...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
