I don't see how that's possible lol...his car got hit on the driver's side, which means he would have had to reverse out of his driveway onto the other side of the road for a car traveling in the right direction to hit him, unless it lost control itself.
Re-do the mission and talk to the NPC's.
Sargent would have explained the traitor after the mission, from your first round.
Ah k. We got kicked out at the end due to being accused of hitting a zombie with a gun. So never got the close out as you've mentioned.
Don't tell me cause birds will hit you haha
only a few days, 30th Jan - Feb 3rd.. No Idea where staying, the missus has organised it with her dad, he owns a couple of apartments up there in some building.. mainly to go see her Grandma whos ill.. but yeh wanna do scuba, but cant imagine myself in a wetsuit.. beached... Also her cousins have access to some jet skis up there.. will do that too!
LOL
when I scuba'ed in Fiji water was warm enough that I jsut went in tshirt and shorts, no wet suit.
same as boracay in the past couple weeks.
Vanuatu I was diving to 40 meters to suited up for that.
for an intro dive you will be doing 9-12 meters so not much cooler than surface temp.
sell car to gen y...
nek minnit...
sucks after the work you put into into it.
thought you were keeping plates?
plates being sent back now
Are you doubting him? The guy is able to count to potato!
Yeh I think it's wet season in jan/feb, so we'll have to see how it pans out. Been wanting to scuba for ages so regardless will be doing that.
if you want to borrow a decent underwater camera buzz me a couple weeks b4 you go and you can borrow mine:
from Boracay
cohhh..
will do, hoping i get the Hero 3 before then(which I should) that thing is amazing under water! but if I dont, will call you.
cheers man!!
how deep are you there?( insert sexual inuendo here )
Am I gonna need a different tow hook setup for my 33 for Sandown? If I do need a tow, my front bar is gonna get destroyed right?
I'm assuming its one of the Support Navara things with a towbar strap and a carbina on it?
She'll be right. i got towed with my stock hook under the bumper bar and I was fine
Toby when you upgrade?
I just took delivery of it!
nek minnit...
Be interesting to see how it plays out with insurance. I agree with everyone here that his story smell like bs
cohhh..
cheers man!!
that was about 9-10 meters
to give an idea
1 meterish:
10ish
20 ish
just over 40 Meters
as you can see the further you go down the harder it gets to see..
the best diving I've done in fiji was in the 8-15 meter mark, lots of bright fish to chase, and your air lasts longer,
(at 20 meters you suck twice the air of 10 meters)
the go pro won't be the best cannot focus in on small details as much as you would like and no flash, (needed often) and no zoom.
oh and as for parasailing.
I treid that as well, but I fkn hate hights and did not like!
to give an idea
1 meterish:
10ish
20 ish
just over 40 Meters
doin it.
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
