I wonder if ethical standards are looking into this at all...
surely they would have to at least take a peek seeing as there is clearly a lot of community angst about 1 particular member
VIC pol pulled down their Facebook post on their page. Everyone ended up complaining in that after they pulled the original page down lol
Well that's gay. Was an entertaining read.
So many uneducated people posting.
People discuss about a defect about DRL's
random posting about 'If he got a fine he deserved it/ if you didn't do anything wrong you wouldn't worry about it! / Glad he got a find and mr pettit is making the streets safer/ damn hoons!
I'll get you the number of where I got.mine (good hookup)
Please tell me DRLs does not stand for driving lights..
Drl stands for daytime running lights
ie BMW angel eyes or led strips etc attached from factory
I could only assume home done ones would technically be illegal if popo wanted to bother as they wouldn't have passed adrs etc for the Vy commos etc
You can have neons, the colors aren't allowed to be blue or red, and you are not allowed to see the globe(or the physical light source)
Hid's are not allowed because you are tampering with a ADR approved head light, and you are not allowed hid fogs, because to pass ADR they need to have jets to clean them
Hence not ADR approved fogs
    • full send the cnut, do this   fark the wrapping and/or stick on siet.
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
    • Finally had these painted and fitted and pleased with the result. also managed to source 400R fender badges.
