What's a good supp similar to jack3d but better tasting and just better period? Usually struggle to stay alive after work
Cbf posting in gym section kunts will just give me pages of absolute crap
Mesonorph if you want an 'upper', rice milk is good of you want some energy though. Rich in carbs and quickly absorbed by the body.
My car was fine through there.. Just bottomed out occassionaly
yeah some real f**ked up dips down there, bottomed out plenty of times surprised my front lip didnt get torn off to be honest..
kinglake, maaaad invite brah.
haha sorry, next time :P
yeah but that's it, though! really hurts the heart lol! :(
so much 'unnecessary' braking because of some of those retarded dips
onehundredandtwentyninethousand
imporeted 2009, major service done by chasers @100k with all busted things replaced and minor done every 5k @ chasers
fuel pump was dead so he just chucked in a walbro toady.
rwc issues are rear rotors too low and radiator leaking
replacing rotors and radiatior if structural test checks out...
then i buy
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
